screamin eagle manual primary tensioner
It is noisy, the SE is probably the noisiest one available. After I installed it in my 2009 and had the bike running I wanted to remove it and take my chances with the auto-tensioner but didn't want to mess with IPB problems and left it in. Been running my SE tensioner for a while and the tighter you run it, the more racket it will make. Every 6 to 8k miles I pull the primary cover to check pad wear. So far so good but probably only have 15k miles on it running Dino oil. I am running it much looser than the oem auto-tensioner but it is mostly quiet and keeps the chain where it is supposed to be.
Do you re-use the outer primary cover gasket or install a new one every time?
Steady Eddy
11-25-2015 03:55 AM
Loc_Tite
03-30-2015 07:08 AM
Orion1369
Touring Parts
06-03-2014 01:28 PM
