stupid question i'm sure, but I am not around the bike right now to go check...
Can the stock brake pedal pad on an Ultra simply be unscrewed and replaced, or will I need a whole new pedal that will allow replacements.
The stock rubber pad slips over the pedal. I think most guys cut them off. I pried mine off to reuse it on my new black brake pedal. I think most the aftermarket bolt on.
ok, so once I pry the rubber one off the pedal, it should have a hole for the bolt on? That's what I was a little worried about. I didnt think I saw a bolt on mine and knew add-on's were bolt on.
