Toggle button on 6.5 Boom system
I just picked up a used 2014 Ultra limited..very happy with it. Coming home I was able to toggle through tracks on my iPhone as I had it connected to the USB port and then into my phone. I did ride through some heavy rain but now at home, the toggle switch to go through tracks doesn't work (volume works fine). Interesting thing is it works when I have it hooked up as BT...could the USB jack be faulty, wet, etc. Any help would be appreciated.
Thanks
Darrell
Thanks
Darrell
Sorry to hear your having problems, these stereos have been a pain in the *** since they came out. I suggest you let the dealer deal with it, it's under warranty. They had to replace my entire system on 2014 street Glide. Still not impressed with this system.
Give my old CD player and all will be good. Good luck.
2015 Boom Box Manual
Since you are just starting to use the Boom Box, I suggest that you down load the 2015 Boom Box manual. The 2015 manual is much more comprehensive than the 2014. You will need to spend a little time in the garage, with the battery tender attached, to learn how to use all of the features.
skibum0607
03-24-2015 06:09 PM
