106" big bite kit with Andrews 48 cams
Received 69,852 Likes
To clear things up:
a stk 96 should crank @ 182 if it is zeroed out deck and running .045 hg (probably less as stock pistons are usually down the hole a bit)
a stk 96 with 48's should crank over at 183 assuming the same(or less for the same reason)
a 106 with 48's should crank over at 212 with .030hg
anyone that claims a 106 and 48's (assuming stock heads) would be just fine w/o compression releases is living in fantasy land
