My spare nacelle dummy switch???
Received 1,504 Likes
Hooray!, I found it. Without your picture, I never would have found that sucker. It was way up front, and buried under the loom. But its exactly as you pictured, powers up and down with the ignition switch, and produces the same voltage as the battery. And of course goes up to 14.00 volts once started and running. So this will be the perfect plug......... Perfect, provided I can find the matching plug end. Is this a dealer only part, or is it some universal automotive plug I can get at any NAPA? Please advise. Thanks!
Ground
On with ignition
On with acc switch
On with brake
If you want to use the switch on your nacelle, make sure you connect to ground and on with acc switch. Although hooking to On with Brake might be interesting for forward facing lights.
The plug you found, is a 4 wire plug.
Ground
On with ignition
On with acc switch
On with brake
Ground
On with ignition
On with acc switch
On with brake
Thanks. Did not know that!
And Thanks for the great replies.
