Pics of seat to console gap on FLHRS?
So I've been looking for a new seat for my Road King Custom but the seats I want that put you further back all are listed for the FLHR/C only.
I've been searching and most people say there will be a small gap between the console and the nose of the seat. Others say theyve done it with no problem. But I haven't found any pictures yet.
If anyone has a Custom with a non-Custom seat can you post pics of the so called "gap"?
Thanks
Thanks
It really depends on the seat itself. The foam is glued to the seat pan and if the seat didn't get enough glue put on the front when it was assembled the foam will pull back over time and create the gap you are referring to and I suspect that is why some fit perfect and some do not. We see this quite often and when we get one in the shop that has pulled back we re-glue the front of the foam to prevent it from doing this.
I don't think there will be a gap on your RK Custom if it has the stock console.I believe the other RKs have a shorter console than yours,the custom has a console like the Street Glide IIRC.When I had my 06 FLHT I bought a RK Custom seat and there was a large gap between the nose and console,but HD made a leather covered gap filler which I still have somewhere.So,I think the seats that will fit the other RKs,will have too long a nose for your Custom.
because the dash on the custom is longer, the nose of the seat is shorter. you will run into problems using a non-custom seat because you'll have a lot of the nose of the seat riding on top of the dash, which is unsightly, and makes for a difficult install. the reverse is also true, if you use a custom seat on a non-custom, then you will have the large gap between the tip of the nose of the seat and the bottom of the dash console.
Ashley at LaPera said in an email that the nose fits really well on the Road Kings which is why I pulled the trigger.
Had an 07 FLHRS I did put on a H-D Sundowner 2 up seat that was model specific, and
some seats from the same year Street Glide are listed to fit the RK custom. The CVO
Road King for a year or two was built on the Custom too. I also have a Mustang solo
seat & backrest that I bough, that didn't give away when the Bike was traded in on the
2014 Street Glide I have now with less then 200 miles on it.
It was a $480.oo seat that I would ship anywhere in the lower 48 States for $200.oo, just saying.
