Axtell oil bypass valve
As I have read in other forums you are not the only one with such experience although some say it works.
If this item was actually doing what it was supposed to do then everybody would comment positively.
Unfortunately a friend of mine purchased same along with the baisley ground precision plunger as present to me and both will arrive next week.
I think I will just place them in the garage locker.
It appears that you have the Axtell system (spring & plunger) coming and also part of the Baisley system (plunger) but not the Baisley spring as they are sold separately. Not everyone needs to replace the plunger so Baisley sells separately.
The stock bypass has a weaker spring than the other two makes the higher pressure by not bypassing until a higher pressure is reached.
I have the Baisley spring only and run at around 50 above 2500 rpm (if only our gauges were marked better). Yes I would do it again
Basically just pulling the CAM cover punching out the pin, etc.?
Good day,
I am going to install the s&s 551 easy cams and the zippers dual piston tensioners in my 2007 96" street glide, I tried to look in the forum for any cons regarding the axtell oil bypass valve however I didn't see find any.
Has anyone installed the axtell oil by pass valve and what is your opinion - will it actually help or it is not necessary.
Also what about the baisley ground precision plunger in zippers website.
Aerated oil is spongy and causes lifter ticking. Also being spongy it results in an oil pressure drop that will cause the piston oilers to shut down. When this occurs engine heat builds and piston & ring life is shortened. Our system directs the bypassed oil into the cam chest to be returned to the oil tank eliminating the "loop".
The Axtell bypass valve's main function is to reduce the aeration of the oil, thereby reducing any foaming.
It also increases oil-flow during low idle, thus keeping the oil pressure up when riding at slower speeds, idling, etc.
Some people swear by this "upgrade" and others see no use for the cost and/or trouble of installation.
That being said, I removed my Axtell oil bypass valve about a month ago and am very glad I did!!
From the moment I installed it, it almost felt like my top end wasn't getting enough oil; similar to how it sounded when an oil pump o-ring failed.
I would have times when the bike sounded normal, but after riding no more than an hour, it seemed to have excessive valve train noise.
(Prior to that, I had little-to-no valve train noise, as I was running S&S 585 cams.)
This lasted about 1-1/2 years, intermittently, until I finally replaced it with the OEM valve and a Baisley 15% spring - LMR-002.
When removing the Axtell part, it was extremely difficult to remove, like it had been out of place/alignment.
Now I'm back to that peace of mind that comes from a quiet valve train!!
I'm running the S&S 570's and haven't had any valve train noise, whatsoever.
After posting up my question I went to the Zippers site and looked up the install. See below listed step 1 instructions.
Step 1: Disassemble the engine motorcycle to the point that the cam cover can be removed.This kit can be installed without removing the cam support plate from the engine if desired.
