No brake light?? help please
Old 05-02-2015, 05:57 PM
kennybe777's Avatar
kennybe777
kennybe777 is offline
5th Gear
Default No brake light?? help please
Hi, i have a 2009 road king im getting no brake light..ive checked the obvious like bulb and fuses also brake relay.. at the fuse box i have power and it works the test light with pulling the brake..when i get to the plug that connects the rear lights i have every light working except the brake??? check the wire and it is good...any help would be great..also can i run a wire from the box straight to the brake wire to check it??
Old 05-02-2015, 06:20 PM
QC's Avatar
QC
QC is offline
Received 19,786 Likes on 9,863 Posts
have checked the pots in the bulb socket? Grounds?
Old 05-02-2015, 08:03 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
TheGrandPoohBah is offline
Received 2,524 Likes on 1,421 Posts
Double check the 15 amp fuse, sure it's clean?
To the rear, I believe it is a brown wire to the brake light.
Old 05-02-2015, 08:48 PM
kennybe777's Avatar
kennybe777
5th Gear
its an led light with turn signals integrated..i ran all new wires to the light..it just at the plug from the fuse box.. i get no power to the plug but there is at the fuse box.
kennybe777's Avatar
kennybe777
5th Gear
i replaced the fuse.
Rich Ventarola
10-25-2018 11:45 AM
Hades02
Electrical/Lighting/Alarm
16
10-19-2017 04:27 PM
Bubseth
13
06-15-2017 10:27 AM
beary
EVO
07-18-2015 08:21 AM
PhatHarley4Me
08-03-2006 10:08 AM
Quick Reply: No brake light?? help please
