Budget 2:1 Exhaust ?
#31
#32
#33
I put a 2010 stock 2 into 1 with a Night stick exhaust on my 2000 RG and it bolted right up. No modifications required, if that says anything.
#34
#35
If you look at my kids road glide, it has bungs in the 02 sensor holes. There is a specific pipe for the 2009 so I would make sure you order the one for 1999 - 2008.. The 09 has a wider frame and different mounting points, because the tranny is different.. the pipe MIGHT be the same, but the mounting bracket will definitely be different..
#36
Road Star asked if I could post a couple of mounting pics. Not the best but gives you and idea. The mounting bracket mounts to the bottom of the transmission with 3 bolts. Then the muffler bolts to the brackets with 2 bolts. you can see we put a couple of spacers on the muffler mount, as it seemed like it was stressing the mount without them.. The bracket itself is also made from stainless steel..
#37
Everything else, including other frame width differences, no problem.
#38
#40
