2006 FLHX Cam Chain Tensioners
Old 05-06-2015, 02:15 PM
Timex's Avatar
Timex
Timex is offline
Default 2006 FLHX Cam Chain Tensioners
At what point should I be concerned about checking these. Thinking about new cams anyway. Don't want to explode motor due to one or both tensioners letting loose. No noise yet from the cam cover area, just want to be ahead of any potential problems. Thanks...
Old 05-06-2015, 02:28 PM
Keithhu's Avatar
Keithhu
Keithhu is offline
Received 5,364 Likes on 2,619 Posts
Probably about 20K. I'd just go ahead and do it with the cams you know you will get soon anyway.
Old 05-06-2015, 04:59 PM
mikelikesbikes's Avatar
mikelikesbikes
mikelikesbikes is offline
You did not mention miles but if you are going to get new cams its a no brainer to replace them (tensioners). I went 74K before ever replacing my tensioners and still in remarkably good shape. Your results may vary.
Old 05-06-2015, 05:11 PM
skully1200's Avatar
skully1200
skully1200 is offline
I converted mine to hydraulic at about 17,000 miles because I was trying to justify upgrading cams. They didn't show any unusual wear and didn't really need to be changed at that time. But, I got new cams out of it, and have no regrets.
Old 05-06-2015, 05:25 PM
keithl3030's Avatar
keithl3030
keithl3030 is offline
changed mine at 24000, don't think if would have lasted another year.
Old 05-06-2015, 06:00 PM
Leftcoaster's Avatar
Leftcoaster
Leftcoaster is offline
I changed my '06 SG to gear drive at 18K. The tensioners needed changing badly as they were nearly metal to metal.
If you're going to keep the bike for some time I highly recommend investing in a gear drive. It's a far better way to go (over the hydraulic system) and you'll never think about tensioners of any kind again. Cost is about the same.
Old 05-06-2015, 10:02 PM
tri cycle's Avatar
tri cycle
tri cycle is online now
64000 miles on my '06 FLHX. Worn, but serviceable.
Old 05-06-2015, 10:39 PM
Mobeus102's Avatar
Mobeus102
Mobeus102 is offline
Default Tensioners
42,000 needed replacing and cams were worn so replaced cams with se204 and the cyco Tensioners and new bearings inner and cam bearings very happy now mine is a 99 ultra tc88
Old 05-07-2015, 04:13 AM
Keithhu's Avatar
Keithhu
Keithhu is offline
As long as crank run out is well within spec...
Old 05-07-2015, 09:02 AM
Leftcoaster
Back in '06 quality control on H-D cranks was much better than in later years so run-out shouldn't be as critical. Still it's always prudent to check it out anyway.
I didn't mention it because it's been covered almost as many times as oil preference.
And any shop doing gear drives checks run-out before buying the parts just to avoid liability.
Thanks for mentioning it just the same, though.
capitan1962
08-17-2015 06:23 PM
hogrunner25
Exhaust System Topics
12-02-2012 08:42 PM
randybullet
09-11-2012 03:17 PM
Jason H
09-23-2010 06:56 PM
OldBoldPilot
10-31-2007 07:13 AM
Quick Reply: 2006 FLHX Cam Chain Tensioners
