horrible gas mileage
#41
#43
fuel gauge read a little less than 3/4 of a tank when i hit the road to go home. i did around 90-95 miles total roughly, a couple rest stops along the way, filled up the tank (that was almost on "E") when i got to my exit on the freeway and it took ~4.75 gallons. haven't done anything more than around town trips since then. if i get the yard work done tomorrow early enough i may have to to head out for a longer ride.
#44
nope, no holes. no smell of gas at any time.fuel gauge read a little less than 3/4 of a tank when i hit the road to go home. i did around 90-95 miles total roughly, a couple rest stops along the way, filled up the tank (that was almost on "E") when i got to my exit on the freeway and it took ~4.75 gallons. haven't done anything more than around town trips since then. if i get the yard work done tomorrow early enough i may have to to head out for a longer ride.
#45
#46
#49
Also I wouldn't rely on one tank to determine the average. Do this over several tanks as speed, weather conditions, traffic and other variable such as terrain can provide higher, lower results.
Pt here very well may be nothing wrong with your bike but you won't know for sure unless you start off will a full tank and divide by the gallons replaced when empty or you fill it up again. Anything less than total miles out of a topped off tank divided by gallons required to top off again to determine mpg is a guess and quite frankly useless.
#50
You need to try your calculations by starting off with a full tank, then filling up at end of tank to get an accurate reading. I am sure you are aware but feel it's worth noting none the less.
He knows it all...
Don't even have to ask him; he'll tell you anyway.
