Air Temp Gauge - Accuracy
I took my SG in for its first maintenance at the dealer and mentioned that the air temp gauge consistently reads about 15-20 degrees above the real ambient temperature. The service guy said that the gauge is not meant to read the outside temperature- that it is intended to read the temp of the air going into the intake, or thereabouts. And, since the motor is hot, it causes the temp to read higher than what the temp would be in a location a ways away from the motor.
Is this guy full of crap, or is that really what this gauge is supposed to do?
If that's the intended purpose for the gauge, then it seems to me that it would make more sense to relocate the temp sensor to somewhere out in front of the bike so that it would read true ambient temps and not be influenced by motor heat. Does anybody know where the sensor is for that gauge?
Steve
Steve
RE: Air Temp Gauge - Accuracy
Well as long as it is 70 or below mine is pretty accurate. When it gets over that it is hot and there is nothing that will cool the fairing down enough for it to be accurate.. But when it gets that warm I am not to concerned with what the temp is. It is warm and that is all that matters..
