Navi system on the uc limited 2014....
Touchdown, I have spent a little time with the HD Ride Planner and the Boom Nav and found it fairly user friendly. When planning a route do not use waypoints as the software will try to go a more direct route. On RP 1st make your route with destinations then go back, right click and select change to waypoint. Save your ride and import. Very user friendly nav system in my opinion. Thanks, Grant.
Not directly. You create a trip, route, whatever you want to call it. Name it. Download onto a thumb drive, Put the thumb drive into the port on your bike and import to your Boom system.
AAR from this weekends trip
So as an after action/lessons learned:
Ride planner works, wish I knew more before I planned the trip. 500+ miles roundtrip from Olympic peninsula, to Winthrop, WA and back.
1. Yes, plan using destinations
2. Yes, convert to waypoints.
3. REVIEW THE ROUTE AT STREET LEVEL. Before you save it, before you download it to your thumbdrive. I wish you could pre-flight the route on the bike.
4. If you leave the destinations as "destinations" you will have to select each segment of the ride individually. If it happens to end at the intersection of oh, I don't know say SR530/I90 you will find yourself learning to use the joysticks quicktime.
5. If you have already passed the beginning of the next segment, don't start at the beginning of the route it will try to route you back to it. Select either the next waypoint or the destination.
6. Did I mention REVIEW the route at STREET Level? I set several waypoints to force it to take the streets I wanted and somehow on the bike, the waypoint shifted 200 yards off the road several times. Result? rolling down the intended path of travel, it wanted a left turn down a sidestreet to go 200 yards and come back and insisted I do that until the end of that segment! I went back to RP and reviewed it. . .and it looked fine. I still don't know why.
If I think of more I'll update this post.
R/
k
R/
k
