Rear Axle Nut Adjuster Adaptor
#51
#52
Check your torque
If you are questioning the correctness of your torque.
Locate a 3/4-1/2 " long bolt to fit your 36mm rear nut.
Attach them to your bumper or any hole of your choice.
Torque it to spec. (or 100 lbs. to make it easy) using your skinny wrench with your torque wrench at 90° ( this is correct).
Now attache your favorite 36mm socket.
Retorque the nut, you will have your answer.
That is all
That is all
