Radio Interference
Radio Interference
Since I've installed my LED headlight (LED bulb into my stock housing), my radio reception has been horrible. I've got the short HD antenna. Everything was fine before I put the LED in. Has anyone else had this issue? Is there anything I can use to shield the antenna cable?
I have this issue with a Truck Lite LED. I have the HD hidden antenna. Changed to the whip antenna and still had the same problem. Put the stock head light back in and no problem with either antenna. I have an 06 FLHTCi. My friends with newer bikes (2010 and up) don't encounter any problem w/LED lights. Any body with a solution, chime in please. TIA......
Trucky911
Trucky911
I will report back on how it worked.
Trucky911
Trucky911
These are the Ferrite Filters that I got.
http://comingsoon.radioshack.com/rad...l#.VWTGk65Viko
They work perfect. I put 2 on the wiring coming out of the LED bulb before it plugged into the bikes harness. I put the 2 of the 3 wires in one and the last one in another. I made loops on all the wires before going into the filter.
On my '08 putting the master switch to the ACC spot turns the headlight and spot lights off. That is how I knew it was the LED headlight and spot lights that was causing the interference.
Forgot to say that I have these on the light and the speakers and they did not help....
Trucky911
Trucky911
Trucky911
Trucky911
