will this rust? what can I do?
So I took the stock exhaust off my road king last night. I found this gouge in my inner primary case. I really don't think I did it, as I've had some work done that required removing the exhaust in the past, and when it's on, this is covered. however, if I did do it, live and learn. I'm over it. my question is, since it seems to have gouged into the bare metal, will this rust in the future? is there something I can do to prevent that from happening? it is what it is now, I don't want to fork out the cash for a new inner primary. I had a leak in my exhaust against the cylinder head and I'm replacing them with true duals. thanks in advance.
That looks to me like something on the exhaust was rubbing against that point, possibly the screw head of the heat shield. Looks like it was "worn" away, not a one time gouge. It won't rust, the inner primary is made of aluminum. Put some black heat paint on it and call it a day would be my advise.
That too.
I'd apply it kinda heavy... drop-wise, then let the heat cure it.
It will never be seen.
Thingfish
EVO
11
03-07-2016 08:00 PM
JaboIam
03-08-2008 11:50 AM
