2000 ultra, what to look for??
Old 06-05-2015, 06:26 PM
pscyclepath's Avatar
pscyclepath
pscyclepath is offline
Default 2000 ultra, what to look for??
May buy my neighbors 2000 Ultra. 47,000 on the clock, minor issues i saw right away.
Anyway,what do I need to look for on this bike?
What can anyone tell me about the EFI on that year?
Anyway, gonna comb the forum and see what i can find out. Thanks in advance.
Old 06-05-2015, 06:28 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
Neggy ZRXOA 5248 is offline
the EFI was not great, and it is getting hard to find people to work on it or parts for it. A lot of people rip it out and co to a carb.
Old 06-05-2015, 06:39 PM
Stiggy's Avatar
Stiggy
Stiggy is offline
Received 5,519 Likes on 3,048 Posts
Mine has 150,000 miles on it with only a throttle position sensor replaced 20,000 miles ago. Rock sol;id dependable in my case. Magnetti Marelli makes efi systems for many different car manufacturers, much as Delphi does.
The weakness is the need to build the motor. My Stage II 95" set up is perfect, but throw a set of performance heads on it and you'll have problems tuning it.
To be fair, some guys have had issues, some like me, have not.
The tensioners need looked at. Because the crank is so strong I went with gear drive cams at 81,000 just over 4 years ago and never looked back.
Get the bike for the right price and enjoy.
Old 06-05-2015, 07:00 PM
pscyclepath
Thanks for the reply,
Im gonna take the bike out for a few hours tomorrow and see how she feels. The current owner is **** as hell so I know maintenance was done right.
He did say the cruise control wouldn"t work for him but Ill have time with the bike tommorow.
It has one of those new fangled cassett players too.
Old 06-05-2015, 09:24 PM
0ldhippie's Avatar
0ldhippie
0ldhippie is offline
MM fuel injection was pretty simple and ok for the time but it is 15+years old. Parts are near non existent and folks who can/will work on it are few and far between. If it is working well it may or may not continue to but if it is quirky now, stay away. Oh the cruise parts (moduals) aren't available anymore either. If ya like restoring non-classic bikes go for it; otherwise... OK I'm being a little harsh, sorry.
Old 06-05-2015, 10:58 PM
pscyclepath
No worries,
I wanna hear the bad stuff and those are some big considerations.
That's why I put em on the forum.
Thanks for keepin it real. starting to sound like a project .
Thank you
Old 06-05-2015, 11:37 PM
DanDman's Avatar
DanDman
DanDman is offline
You may have no major issues if it was well maintained, and had the cam chain tensioners replaced.
I had put 25k (10k previous owner) 35,000 total miles on my '00 MM injected bike with only a intermittent high idle problem. Which I could have fixed if I had chose to. But instead, I redid it with a 95" bore, ported heads, new cam plate & tensioners, etc. I went with a S&S Throttle body & ECM, which really woke it up...But I'm on the fence if I should have changed to a carburetor.
I also added Cruise Control recently, all new parts off of ebay.
One negative is fuel filters for '00-'01 go for $100+.
Old 06-05-2015, 11:38 PM
bikerlaw's Avatar
bikerlaw
bikerlaw is offline
As mentioned, the cam chain tensioners would be my biggest concern. If they have been replaced or upgraded (with proof), your fine. If not, they are on the verge of disaster and need to be addressed. That is where I would start my questioning.
Old 06-06-2015, 01:32 AM
Steddy's Avatar
Steddy
Steddy is offline
Had mine for about a year now. Totally rebuilt. Has the MM setup. When I rebuilt the motor (outer cam bearing went south) I put the gear drive with cams in. Pretty solid with a Dobeck fuel adjuster module (adjusts like a carb, piggyback system). After putting that on, the injection problems went away, but I'm a carb guy, so making this sort of imitate gave me that "carb tune" advantage that woke up the SE 95".
Jeffkory
04-28-2018 10:22 AM
Bartender
02-25-2017 10:46 AM
kamut
02-11-2011 07:48 PM
cpmman
10-13-2008 07:34 PM
Snipman
07-20-2007 09:16 AM
Quick Reply: 2000 ultra, what to look for??
