2013 Street Glide Spark Plugs.
Old 06-08-2015, 04:44 AM
Spitz88's Avatar
Spitz88
Spitz88 is offline
6th Gear
Default 2013 Street Glide Spark Plugs.
Im going to replace the plugs in my 2013 street glide with the 103 and I've been looking up what plugs everyone runs and haven't found a good solid answer. What the best bang for your buck?
Old 06-08-2015, 07:49 AM
craigffb's Avatar
craigffb
craigffb is offline
I just use plugs from the Harley dealer. Never had any issues with them.
Old 06-08-2015, 08:03 AM
GriffinDenim13FLHX's Avatar
GriffinDenim13FLHX
GriffinDenim13FLHX is offline
Pine Tree's Avatar
Pine Tree
Pine Tree is offline
MODERATOR
Received 1,964 Likes on 463 Posts
Stock plugs...
Old 06-08-2015, 08:10 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is offline
Received 1,810 Likes on 1,063 Posts
Stockers.
Old 06-08-2015, 08:18 AM
SD lumpy's Avatar
SD lumpy
SD lumpy is offline
X2 on stockers
Old 06-08-2015, 08:21 AM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
Neggy ZRXOA 5248 is offline
the OEM plugs are normally cheap enough
unless you have done something that requires you to change the heat range, then stick with what works
Harley uses a funky system to detect misfires, and it is heavily integrated with the plugs, wires, and coils.
Change those items away from OEM or a part that is known to match OEM, and the commuter does funky things.
there are no "magic spark plugs", although some of the multiple electrode plugs work well in high performance engines... we can get into a discussion of flame travel in the combustion chamber if you'd like, but from my experience the OEM's work just fine.
Old 06-08-2015, 08:23 AM
FNGonaRK's Avatar
FNGonaRK
FNGonaRK is offline
Received 7,640 Likes on 2,668 Posts
Yep. I tried the fancy NGK's on my Road King and it threw a check engine light at about 70-75 mph, consistently. Changed back and the problem went away. The problem went away and the bike ran better. Stockers for me from now on.
Old 06-08-2015, 05:55 PM
Spitz88's Avatar
Spitz88
Spitz88 is offline
6th Gear
I appreciate all the feed back. Thanks everyone!
Old 06-08-2015, 06:04 PM
AZdryheat's Avatar
AZdryheat
AZdryheat is offline
Harley store is too far away so I buy what I can elsewhere. I use NGK Iridium plugs and love 'em. No codes, no issues. And don't use anti-seize with NGK's per NGK (and most all of the other non-Harley brands per them). And check your torque after a ride, I've had my rear plug loosen up so I give it a couple of extra pounds.
cptdenny
2014+ Touring Models
13
02-06-2019 09:43 PM
Napalm Dog
12-10-2012 09:43 PM
sprint12
12-13-2011 05:11 AM
stuntdad
11-17-2010 05:28 PM
corona
Exhaust System Topics
03-05-2007 08:34 PM
Quick Reply: 2013 Street Glide Spark Plugs.
