2012 street glide won't start.
Old 06-15-2015, 01:43 PM
KW HD's Avatar
KW HD
KW HD is offline
Default 2012 street glide won't start.
My 2012 Street Glide won’t start.
Went to start the bike. Always on the tender when parked. Kill switch on run, ignition to run, hit start button. The engine chugs once (turns over) then nothing for a second then a loud clicking from the starter reverberating through the primary. Not a pleasant sound! I also noticed after this attempt the headlight goes dimmer than it should. When I plug the tender back in it shows the battery to be discharged more than it should after this one start attempt. I checked battery connections, tight. I put a regular battery charger on and it shows battery near full. Definitely a” flaw in the slaw” somewhere. I don’t want to have it towed in to my Indy to be told it is a bad battery or something I could remedy!. Thought I would run it by the experts here first. I don’t have a multimeter, should I get one? Thanks in advance for any help or suggestions.
Old 06-15-2015, 01:49 PM
96roadking's Avatar
96roadking
96roadking is offline
Check your battery cables (both ends). Check the ground connections and yeah, get a multimeter and do the recommended checks in the service manual, starter solenoid, voltage regulator, stator etc. Check voltage on your battery (charged) and you can get Autozone to check your battery free.
Old 06-15-2015, 04:24 PM
KW HD's Avatar
KW HD
KW HD is offline
Thanks Jeff.
Old 06-15-2015, 04:30 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,540 Likes on 3,792 Posts
My two cents....NO REAL MAN CAN LIVE WITHOUT A METER. IF YOU NEED THE MAINTENANCE CHARGER ALL THE TIME, YOU NEED A NEW HOBBY. Preaching over...now the facts.
After a good 24+ hour maintenance low amperage charge, with the charge light in the solid green and the battery has set about 24 hours off charge, voltage should be about 12.8 volts.
12.8 = full charged
12.6 = 75% charged
12.3 = 50% charged (Lot of new modern cars with system protection will not even click at this point but will have good headlight beams showing)
12.0 =25% charged
Always check both the terminals at the battery lead and also at the terminal on the wire. That helps to verify connection.
With a DC volt meter (one that has a feature to lock high and low reading is best) hooked across the battery terminals and reading 12.8 or so, crank motor and while its cranking it should not drop below about 9.6 volts and as soon as it starts and throttled up to 2000 rpm, voltage should read around 14.8 volts. The 2000 rpm is the bench mark standard. Ignore idle output. Ignore output above 2000rpm unless it exceeds 14.9 volts. That is a sure indication that regulator is bad.
The crank check shows a rough check of the reserve amperage capacity of the battery while cranking with a 150-200 amp load on it. The 14.8 shows a good alternator and if you leave it on a while as the regulatory will drop the voltage a little showing itself working. However, with the lights and stuff always on, it will never drop back much. If you have a lot of options, most modern bikes will not show 14.8 charging volts at idle but stock newer bikes will be close. Older bikes with lower amperage output not so much. However, 2000 rpm is the bench mark for the standard 14.8 volts.
If you think battery is good and something is draining it sitting, now would be a good time to check for drain problems. Go to Harbor Freight and get you a AC/DC meter for under $25 or so. http://www.harborfreight.com/ac-dc-d...ter-37772.html Make sure it has DC amps draw, DC voltage, resistance and AC voltage. Key off. Remove the negative cable off the battery. Set meter on DC amps. Hook the meter lead to cable and the other to battery. How many milliamps (mA) is it drawing? It should be no more then 6 mA which is the ECM (1), speedometer (1), tac,TSSM (1),HFSM (1) and voltage regulator (1)
When a battery wears out, a good charge will show fairly good voltage, but the battery can still have very low amperage capacity which will show in the crude crank test above, but it really should be checked after a good charge by removing it from bike and getting a free check at a place like AutoZone that has a fancy load meter check that gives you a print out of the battery health. Battery MUST BE CHARGED to check it. Be sure they set their meter to correct cold cranking amperage stated on the battery. Never charge the AGM absorbed glass mat battery with a regular car battery charger unless it is a newer one that says safe with this type of battery. Also, by taking battery out you now know you have good connections. Vibration tends to loosen the connections or a little corrosion will prevent charging or cause starting problems.
Using the maintenance charger can get more years from a battery but be careful here. You do not want the last start 5 miles from home. If it still grunts when you first hit starter or kicks back with a bang, replace it. After a few years, charge and pull battery and have it checked for cold cranking amperage ever spring. Even then, if it grunts most ever start, I would replace it. If they have one that fits your bike, Wal-Mart's AGM absorbed glass mat battery is just as good as any for one third to half the money of a Harley Battery. Do not jump, push start or run bike with a half dead battery except in an emergency. If a bike battery is down and you jump it, throwing all that amps to it from a big car battery especially one that is running can wreck a bike regulator or charging system. Charging a worn out battery can kill alternator stator or the voltage regulator or both. Probably ending in a big dollar repair.
It is also a good idea to always check your battery at 2000 RPM with your meter set to AC. If by chance, the regulator goes bad, sometimes it will let AC come thru. That is a sure sign of a bad regulator. The older stators with two wires are a two phase AC system. Lot of people call it a single phase but it is two phase. The AC voltage you see appears single since you check it AC across the two wires since there is no earth ground. If you were to check one wire to an earth ground, it would show one half the voltage that you would see when you check the two wires together on the bike. Same with the other. Together they double and are two phase. The newer three-wire system is a 3-phase AC system for the higher amperage output.
Also remember, when starting a Harley, hit the starter and hold it in till it is firing on both cylinders and running before letting up. There is a fraction of a second more for a long stroke Harley then a multi-cylinder car for it to get going. If you do not do this, it will kick back with a bang or crank a lot longer the second time or shame on you the third time. Also, if you have a habit of doing this, the starter solenoid switch contact will only have half the life it could. You cannot hurt the starter. The starter gear has a sprag clutch. There are drive pins in it that as the gas motor catches and run, it outruns the starter motor drive and disengages it from the electric motor.
glidein wide
EVO
07-17-2017 07:05 PM
ssbogger77
Electrical/Lighting/Alarm
06-03-2017 08:56 PM
JPD17
05-15-2017 07:00 AM
Jeff47
05-02-2017 08:21 AM
m craig culver
10-08-2015 01:42 PM
Quick Reply: 2012 street glide won't start.
