Taking Limited in Toy Hauler
Just got back last week from 2500 mile trip. I have a 2005 GMC dually i ton with a 11.5 ft lance camper and a 6x12 ft enclosed trailer for the limited. I had to build an extension hitch but the trailer was perfect for the bike plus I took an aluminum truckbed tool box and mounted it to the inside front of the trailer, it was perfect for all of our riding gear(coats, leathers and helmets).
Went from the Phoenix area to Junction City Oregon rode to the coast then worked our way back down to the San Francisco Bay area and spent a week riding around there. The bike always had a garage to be parked in.
I've put 1000's of miles on the my toy hauler with the Ultra in the back and the key fob in the tour pack. As long as the key fob is near it you can move the bike all you want without the alarm going off.
Think about this, I do this all the time in garage on the jack without the alarm going off so not sure whey they are saying this is an issue.
Couple recommendations
1) good wheel chock as someone mentioned
2) Tie down at the front forks where the fender connects to the D rings in the floor
3) make sure you tie down the rear wheel
The back of the toy haulers bounce around ALOT
if you have an audible alarm/siren - the siren is disabled with FOB present - this is true. The motion sensor is not (until ignition is turned on)
With ignition off, every time the bike moves, the HFSM will "poll" (look for) the FOB - if it finds the FOB, lights won't flash, etc (without FOB, the lights will flash).
The issue is not whether or not the alarm sounds or the lights flash. the issue is the constant polling for the FOB will draw on the bikes battery and eventually, given enough time, the battery voltage will drop enough the bike cannot be started.
The Owner's manual explains how to put the bike in transport mode - which maintains the security preventing the ability to start the bike without a fob, but disables the motion sensor so the bike won't poll for a fob with every movement. This will allow you to not have to keep the FOB near the bike (not very secure if the FOB is near the bike allowing someone to start the bike.
When you are in your garage moving the bike around, unbeknownst to you, the HFSM is polling for the FOB every time you move the bike.
Here is explanation regarding security system.
I've heard of guys hauling from the Northeast to Florida for bike-week and arrived with a dead battery. Maybe they were just unlucky. If the hauler has 110v power when in transport, could always plug a tender in while towing.....
