How high can I go?
i would say go 16 or more. what ever you decide is best fit i suggest going to the next step up. almost everybody i talk to and myself end up saying i wish i went 16 instead of 14 or 18 instead of 16 ect. restricting to bars that alow keeping stock lines and cables are not going satisfy the comfort you need most likely
height. i was guilty when i put 14's i wished for 16's. when i did 18's i kinda wished i went 20.
Hello all, I'm new to Harley ownership, I have a barebones 2001 FLHT... I'm 6'4 and did just over a thousand miles and I can't turn my head for the pain in my shoulders. I have buddies with varying heights of bars and it feels much more comfortable than me reaching down for mine. My question is how high can i go without having to change all my cables and wires?
Thanks
Thanks
Ontario Regulations 596
(10) No person shall operate upon a highway a motorcycle or motor assisted bicycle equipped with handlebars that are more than 380 millimeters in height above the upper most portion of the seat provided for the operator when the seat is depressed by the weight of the operator
Ontario Regulations 611
4. (3)(e) No part of the handlebar shall exceed a height of 380 millimetres above the uppermost portion of the operator's seat when the seat is depressed by the weight of the operator.
One VERY important thing if you put taller bars on. You bike has a 2 piece handlebar clamp as stock. You will need the one piece "dog bone" clamp. The added leverage will cause the bars to eventually fatigue and crack at the wiring access hole in the middle. Mine snapped in two, luckily while backing into a parking spot. The 1 piece clamp will prevent this.
That said, I'm 5' 10" and have 14's on a '01 RK. Just put 14s on wife's softail and she's 5'5" at most, but overall width is "35-36 vs my "39-40.
Too much pullback will create a wrist angle that will put your elbows in your ribs during tight turns.
Lots to consider...Height, width, pullback angle on the wrists etc. Take your time, ask to sit on a few bikes. You'll be glad you didn't rush it.
