Freedom slip-on mufflers on Road King
Just got my Road King Police 2014 and thinking of changing the stock pipes. I am thinking of taking the Freedom slip-on mufflers (got a good deal on them) but honestly speaking not sure would I need to change the air filter as well and go for the Stage 1. I am reading confusing posts where some are saying with slip-ons you do not need to got for the new air filter/tuner and some are saying its a must. Thanks in advance for your help!
I did a complete stage one on my 2013 Limited this spring. I installed a de-catted pipe, K&N AC, CFR Slip ons or Rinehart Slip ons with a Power Vision 1 tuner. After going through it I would recommend you start with a good tuner and then do the add ons. The OEM tune from HD is already lean and leaves a lot of performance unused. Being lean from the factory and a catalytic converter just add to the heat problem. Good luck with your project.
Bill
Bill
Hopefully the take care of you and this is just an isolated incident of bad prep for chromium. I have Freedoms on my Bully end it has holden up with no issues. Good luck!!!
NETacomaFatboy
05-16-2013 12:53 PM
bdavis
06-26-2012 12:08 PM
