Wild 1 16" Apes on Road King - Cable Length
Old 06-26-2015, 04:45 PM
bsdoig's Avatar
bsdoig
bsdoig is offline
Default Wild 1 16" Apes on Road King - Cable Length
So i've decided I'm going to put some 16" Wild 1 WO509's on my 2012 Road King(abs). I've been researching on cable lengths and the general consensus seems to be +8 cables on the clutch/brake.
Can anyone confirm what length cables they used? I would like for the cables to fit well and not have a ton of extra clutch or brake cable leftover.
Also plan to go with +12 wiring extensions.
Old 06-26-2015, 06:01 PM
bikerlaw's Avatar
bikerlaw
bikerlaw is offline
I have 509's on my 13 Road King. I initially thought the shop (yeah I wimped out) installed +6, but they were all +8. He hand made the wire extensions one by one, and staggered them, so I can't tell you what length they are.
ALso, well placed cable clamps really make a difference in how cables flow on the bike. I got my clutch cable perfect, still working on the brake line. That's gonna need a different angled fitting up at the master due to the excessive overhang of the 509's.
Old 06-26-2015, 08:27 PM
bklynbob's Avatar
bklynbob
bklynbob is offline
Go 12 on the clutch,18" on the wiring and 8"-10" on the brake line.
Old 06-27-2015, 10:15 AM
bsdoig's Avatar
bsdoig
bsdoig is offline
Anyone else have any suggestions?
Old 06-27-2015, 10:23 AM
crimson13's Avatar
crimson13
crimson13 is offline
Plus 8 for me on my RK ,LA Choppers 16" Tree Huggers
Old 06-27-2015, 10:55 AM
SeniorChief56's Avatar
SeniorChief56
SeniorChief56 is offline
Received 16,379 Likes on 4,708 Posts
just go to the dealer and get the SE Throttle Grip Sensor. It's about 110 bucks. Eventually you may have problems from splicing the wires. You can spend 7-11 hours splicing and heat shrinking your wires, or you can get the SE plug-n-play kit, installed in 1 hour or less.
Old 06-27-2015, 11:00 AM
bsdoig's Avatar
bsdoig
bsdoig is offline
Does this not just cover the throttle assembly? U still have to splice/solder all you other controls right?
Old 06-27-2015, 01:12 PM
ndnguyd's Avatar
ndnguyd
ndnguyd is offline
Went with +8 for my 16" wild1s.
23Seven (07-16-2022)
Old 06-27-2015, 04:30 PM
SeniorChief56
http://www.harley-davidson.com/store/twist-grip-sensor
stbobshadow
04-01-2016 03:17 PM
SBRoadKing
02-17-2013 05:40 PM
fourH-Ds
08-21-2012 08:49 AM
leukus
06-02-2010 05:40 PM
miralas
10-02-2009 12:33 AM
Quick Reply: Wild 1 16" Apes on Road King - Cable Length
