New member with an issue. I have a 2001 electra glide with 108,000 miles does not leak any oil or smoke but every 3 or 4 hundred miles I need to add about 3/4 of a quart of oil. I cannot think of any issues maybe you can help.
My 2000 has 150,000 miles on it and still uses little oil but i installed new (take off,) heads at 75,000. You won't know until you do a compression and leak down test but if I was to guess I would suspect valve seals.
This sounds more like it. Neither test is too difficult, you may need assistance keeping the rear wheel from spinning on the leak down test.
