does my 09 have TSM / TSSM / HFSM module?
you have a tsm (turn signal module)
the tssm (turn signal security module) is the hdi equivalent of the hfsm (hands free security module). but you said you don't have security, so that leaves you with the tsm. not 100% sure on the police bikes, but on my road king, it was under the seat.
I can't help much on your other question, sounds like you have something shorting to ground. oh, btw, electrical gremlins suck
thanks guys! I found it!
Also found the short....with the ignition fuse out, ohmmeter on the dead side of the fuse, turn key on, got a reading....press the starter button and the ohms move all over the place when the steering is turned....
Found the wire from the starter button BK/R was worn right at the connector in the fairing. Fixed that and the ohms don't change anymore, no more shorting to ground!
HDF Tech
Electrical/Lighting/Alarm
01-28-2006 04:04 PM
