can't get cassette out of player
Old 07-04-2015, 08:46 AM
ditchbanger's Avatar
ditchbanger
ditchbanger is offline
Stage III
Default can't get cassette out of player
does anyone know how to get a stuck cassette out. it come halfway up bu wont shoot out.
Old 07-04-2015, 08:52 AM
0ldhippie's Avatar
0ldhippie
0ldhippie is offline
Slide puller?? Might just be time to upgrade... Welcome to the forums!
Old 07-04-2015, 08:58 AM
KW HD's Avatar
KW HD
KW HD is offline
The tape itself is most likely jammed up in the pinch rollers. Sometimes if you can't get it out you can cut the tape and then use some Scotch tape and splice the tape back together. I don't think you'll be replacing that cassette with a new copy. Good luck.
Old 07-04-2015, 09:02 AM
BigWaterJim's Avatar
BigWaterJim
BigWaterJim is offline
Good now you can justify coming into the new millennium and upgrade.
Old 07-04-2015, 09:13 AM
campos's Avatar
campos
campos is offline
just had to read because I can't believe people are still using cassette tapes. That's awesome
Old 07-04-2015, 09:20 AM
babygorilla's Avatar
babygorilla
babygorilla is offline
Had this happen to me WAYYYYYY back in the day. Had to remove deck. It was an aftermarket one so not a big deal. Once that is done I could manually push back the rollers and the read head on the HU.
I then replaced it with a CD player and converted all my tapes to CD.
All happened 30 or more years ago, lol.
Old 07-04-2015, 01:05 PM
larsfum's Avatar
larsfum
larsfum is offline
There is a way to manually eject it. Turn the radio off. Take a small, long handled allen wrench and insert it on the lower right hand side of the cassette door until it makes contact with the tape carrier mechanism. Gently push against the tape carrier until the tape moves up and out. Don't force it. Finesse it.
I don't listen to tapes, but I do own a nd use my service manual.
Old 07-04-2015, 01:09 PM
bikerlaw's Avatar
bikerlaw
bikerlaw is offline
My 1989 S10 had this problem. I pretty much gave up, took needle nose pliers, and yanked it out. Then I went and bought an Alpine head unit and installed that. Life has been much better since.
Old 07-04-2015, 01:22 PM
RollaMo's Avatar
RollaMo
RollaMo is offline
I haven't used (or had anything that would accept) a cassette in years!
Are the tapes even still available for that format?
Old 07-04-2015, 02:16 PM
big papa AZ's Avatar
big papa AZ
big papa AZ is offline
No ****.
Quick Reply: can't get cassette out of player
