kuryakin engine guard
Received 70,260 Likes
[QUOTE=Captain Kirk Schneider;14176747]I wouldn't buy anything from Kuryakyn. I think it's all junk. Go with the Lindby bar. Well made. Got the Magnum on my Streetglide. My two cents[/QUOTE
I think some of Kuryakyn's stuff is tacky, but much of their stuff is first class, as is HD's.
Just because it says HD does not make it any better.
Furthermore, Kury will stand behind their product and you do not have to have a "receipt".
Try that w/HD even your local and even though they know you bought it from them, w/out a receipt you will not be able to return or exchange.
I have several Kuryakyn products that have been well made, and are holding up very well. Any issue I've run into they take care of no problem. I received my driving lights/turn signals and one of the tabs that hold the turn signal lens on was broken. They gave me a set of LED turn signals for free. The upgrade to led is like $90. First class customer support.
OP you should call them and ask someone there if it will work, or the reason why it won't. I can't see why it would fit a 14 but not a 15.
I have a few things from kuryakin and the quality on those are good, but some of the stuff looks pretty cheesy. I emailed them and got a response saying they didn't have any info on a ergo plus for the 2015 street glide, and to check there website often. Typical response I guess. Don't see any reason why it would not fit either, just figured I would ask here before I spend the money.
