Help, just installed 10" LA Chopper handlebars, no throttle response
I don't know the procedure right off , at work , but should be In the owners manual.
The green plug is super fragile and very few have luck pulling it through the bars without it breaking
Good luck sounds like you have it going your way.
The only other possibility is that you may have to disconnect plug behind the air cleaner, spray it with electrical contact cleaner, apply a very light coat of dielectric grease, and reconnect.
However, it is most likely that the codes are being caused by mismatched voltage (0-5v) from your TBW-TCA. Even if the green plug appears to be intact on its exterior, the slightest concussive stress and/or twisting, crushing etc will cause its internal pins to misalign and fail, thus causing your codes.
I bet you a Ham Sandwich your most likely resolution would be to replace the "Green Gremlin" with the HD Extended TBW/TCA Assembly. $105 and a few tears...
Hope it all works out for you.
Ride Safe and Ride Often. Rubber Side Down. Over and out.
2010 Limited with some stuff
they are not clearing because you are still having an issue with TCA and/or the TBW Plug.
