Battery Problems
the "tender" is meant to "tend" to a charged battery...it has maybe 500mA ( 1/2 an amp) capacity
a battery "charger" charges a battery and a good amp rate is 5 to 7 for your battery.
overnight or better
the idea is to fully charge the battery then load test at autozone- it;s free
tender tends/charger charges
I have posted before on my neighbor who assumed he knew what his problem was and the dealership who did work up to $1300 mostly based on his direction.
In the end we found a bad battery cable...$15 fix
diagnosis is key to a correct repair
mike
overnight or better
mike
Received 2,524 Likes
my blue flame stove bolt (motor and 3 speed transmission out of a 51 car but I still have the 47 and 4 speed)...HA
Batteries usually fail in the heat of the summer or in the dead of the winter.
Keep it on a tender when long periods of time are anticipated.
I had a battery on an Iron Sportster that lasted 6+ years by using this method.
Well I left the battery tender on last night, tender showed battery charges, I checked with volt meter, 12.6 volts, bike started just fine, I again checked volts with engine running, 14.6 volts, so I was mistakened earlier when I said 15.6 volts, sorry, I then shut the engine off, two minutes later, she wouldn't crank?? I'm thinking time for new battery. Thanks to all whom responded!
Just wondering how old the battery is and what the mfg is ,HD?
If you want to save approx $75-80 and get the same type AGM maint free factory activated replacement battery that HD sells that proven to be a reliable long lasting battery then check out the links below.
Scott
http://www.tristatebattery.com/etx30...ery-p-982.html
http://www.batterymart.com/p-Big-Cra...L-Battery.html
Sandstorm29 (02-25-2024)
"I then shut the engine off, two minutes later, she wouldn't crank?? I'm thinking time for new battery. Thanks to all whom responded!"
This scenario could be a number of things depending upon what is meant by "wouldn't crank".
If it means it doesn't turn over at all, as in just sits there dead silent, it could be the solenoid points not making to the starter motor itself.
This occasionally happens with my '07 RKC and I have a piece of wooden handle from a hammer that I tap the solenoid with while pushing the button.
The first time this happened to me, I proceeded to take things apart, fuses,switches,etc... and found nothing wrong, I smacked the solenoid with a screw driver handle and tried it and voila, she cranked over and started.
It hasn't happened in a long time, but I somewhat am used to the idea of it coming back to haunt the old '07, hence the carrying of the baton.
Now if it means it turns over,slowly,,, and won't start as in fire up, that more than likely is the battery giving up the ghost.
Might have a bad cell or two, or plates are just over sulphated and it needs to be changed.
Remember how the old cars with a dying battery would give the tell tale chatter of the solenoid and all it took was a guy that knew how to jumper across the points to the starter and get himself and his girl home before midnight.....L O L
