Compensator Replacement - Parts List (?)
Originally Posted by Seattle07Glide
This is the starter clutch you need.
Amazon.com: All ***** REPLACEMENT CLUTCH ASSEMBLY 79-2104 06 DYNA, 07-10 BIG TWIN: Automotive
2010 Limited with some stuff
No glue in deal with the Baker but you do need the new style HD Rotor.
I had the rotor from the se comp kit i installed in 09 so if this is your second time that rotor works.
-375 w/forum disc for the baker
-0 reuse gasket
-some oil
-0 if tensioner is ok, I have had awesome luck with the hayden(100$) on my 07(other yrs not so lucky)
-38 for oem starter clutch on ebay. but this is just the gear and have not installed yet, still some grinding on hot starts,unless i start as soon as i turn ignition on.hope is works.
-tap or chaser(got the kit from hf for 65 for other projects)there was a lot of gunk in there.
-optional cleaning fluid and anti seize
-I measured away,,, and could not see any chain alignment issues.maybe let your buddy help you with this.
-grinder or drummel tool to file the IP if its first time.
-0 reuse gasket
-some oil
Does the chain adjuster tend to break? In researching my problem I haven't seen any talk about that part going out, but I haven't really been looking either so I'm not sure how prone it is to giving out
A strip of metal sheared off of my rotor and broke my chain tensioner.
Assuming I do the grinding to get the part out and not take off the inner primary, I can go without that gasket that I linked in my initial post. I just realized I don't have the outer gasket part number - does anyone know it? When I search on the HD site, the only one that comes up is the black inner primary (http://www.harley-davidson.com/store...-inner-primary)
