Ok, here is one for ya
2010 Limited with some stuff
I did disable the parade mode. Waiting to see if that cures its ill. Not sure if it will, as its an intermediate problem. It did it at random and maybe I can reproduce it. Wish it were like a flat tire, then you can fix it and move on not have to wonder "is it fixed"? "Was the the problem"? "maybe"? Hate those kind
Well that didnt work, did it twice to me since. I talked to one of the mechanics at Indy HD and he said it sounds like the ecm needs reprogramed (maped). Afraid to find out what that wll cost.. Anyway, if thats the culprit, would replacing with a thunder max take care of it? I realize it will require dyno and maped.
Doubt it is the ECM... but it does sound like "Limp Mode". A couple things will set that off.
Look up posts on the early 08 fuel pump filter housing issue. Low fuel pressure will do this.
Also look for any error codes, although low fuel pressure will not pop a code.
http://www.fuelmotousa.com/p-29661-h...ble-codes.html
Could also just be a faulty Throttle Grip Sensor which will show a code...
This moring I got it into Brandts HD in Wabash. They pulled the codes and found that under the left cover some terminals were damaged and said they needed replaced. I had to set an appointment time for the third of next month at 9am.
They said this would cause all my issues including cruise control not holding speed.... Ok. Well we will see.
Thank you. I have bookmarked the page.
