speed sensor
speed sensor
ok iwent to the hd dealer to get a new speed senser for my 2000 road king classic but the parts guy said there no such part he called it a crankshaft position sensor part#32798-00 so is this the same part and if it is isthere away to test it. i tried to clean it with wd40 did not work any advice will help [sm=feedback.gif] the speedometor and milage meter dont work when i turn key on the gage dose move but dose not regester when rideing so i guess im asking in a electronic speedometer is the speed sensor the part that makes the speedometer work and is thatthe correct name of that part
fortbisbee@msn.com (09-10-2016)
RE: speed sensor
So you didn't find a sensor on your transmission just to the right side of your starter? I guess its possible that the crankshaft sensor would do double duty, but if you have a sensor where I told you to look, then its also just as possible, or even more so, that you have one of those dumbas$ parts counter 'technicians'. I am very blessed that I have parts counter staff at my local HD who actually turn their own wrenches and know the product VERY well.
PS...They eliminated the crankshaft position sensor on 2001 model bikes, so I can't tell you for sure what is right for your bike.
I'm actually experiencing the same thing on my 2001 Road King. The first time I removed the sensor there were a lot of shavings attached to the sensor because it seems to be a magnetic pick up. I cleaned it and reinstalled it. My speedo and blinkers started working normal again for about 150 miles then the speedo started bouncing around again and after a few minutes stopped working. I decided to change tranny fluid and flush the tranny to try and remove any metal residue. It seemed to do the job but stopped working again. My next step will be to just replace the sensor.
The crank position sensor has nothing to do with the speedo. It is pretty much strictly for engine management.
The speed sensor is mounted on the transmission. I haven't really looked into exactly how it works but my bet is that it reads the rpm of the final drive and the computer derives vehicle speed from that.
I'm sure it's probably a hall effect sensor and has a magnetic field.
If it becomes fouled with shavings and works when repeatedly cleaned then works for a while then it probably needs to be replaced. If the trans has a lot of shavings floating around then I'd suggest draining it, putting in a cheap fluid, driving a few miles and draining again. Personally, I'd repeat the drain fill cycle a couple of times then replace the sensor and put good fluid in the tranny.
