Still chasing an oil leak
Received 4,309 Likes
Decided to loosen the top bolt and spray the gap in question with the permatex copper spray a gasket & sealer spray hopefully it fill in in the nooks and crannys. I will hit it again with permatex hightemp rtv sealer and see what happens.
Ok so I rode it again today, but short enough that it didn't blow all over, and long enough for it to leak enough to find the source.
Not sure what to think of this, I'm not sure if this is cracked for just the way it is put together. Im guessing the cases will have to be split and re sealed. Looks as if there is a white sealer that bonds the cases together.
Here's a pic, let me know what you think:
from your pic , the oil is spread there , it is not coming from that area . mine looked like that too when i did the stator. wash it again and spread oil degreaser to clean up then test ride , and follow the new mark of oil. it could be oil filter too
this is what i used to clean up :
http://www.autozone.com/fuel-and-eng...er/522149_0_0/
spray and clean with shop towel or anything else let it dry then test ride.
I just had the same problem. My 2006 was leaking from everywhere including tranny.
I pulled inner primary off and the race for the main shaft had walked in and pushed the seal out, my exhaust bolts were causing the tranny to leak and the stator plug was leaking.
Honestly, pull it apart including the inner primary. Replace the main bearing (runs from tranny to the back of the inner primary with a one piece sealed bearing). Put in new gaskets everywhere and put back together. Used goop to seal the stator plug.
Problem solved.
Problem solved.
