Anyone using Ohlins #2-#2 (a) shocks by Howard
As for shock height. I went from a 11" progressive to these ohlins and they sit just a tad higher. There is no clearance issues. As far as 2 up you just have to adjust the preload collar. Lots of times my wife will jump on for a ride without any extra adjustment when they are set up for solo. I would say they will sit at a very similar height to your 11.5" shocks. If we were to go on a long trip then I would re adjust the shocks for 2 up but I have not seen any reason to adjust yet.
I installed these shocks after only 500 miles. The stock premium adjustable shocks rode very hard even over the slightest road imperfections...and in New York there's a lot. I ride mostly solo, but the adjustment to increase the spring rate is easy. A lot depends on weight. I ride with a buddy who is about 235lbs and has a 2015 RGS. He doesn't mind the factory shocks. I'm 210lbs. I got mine through Howard...very helpful.
I have the 2.5's, which is the #6 without the separate reservoir, but are adjustable as well as having a longer stroke than the #2 or 3's. Best upgrade I ever made! Do your homework by reading all of Howards info on his web site and your experience with him will be educational and rewarding should you choose his shocks.
badbs101
04-11-2008 05:46 PM
