2015 Ultra Limited saddlebag problem
Washing the new bike today, took my bags off, and behold, the saddlebag support only on the right side wearing the paint off on the inside edge of bag.
Anyone else seen this? Tried adjustment only on the lower arm, nothing helps. Pics are attached.
Starting to assume warranty issue.
My 14 Street glide has the same issue,except it is on the left side.If you remove the bag and slack off that bolt shown in your pic,you can raise the support a bit and that may reduce the chaffing.I did it and put a piece of heavy 3m protective film on the chaffing spot.I think it is caused by the bag leaning in too far at the top,which could be cured by putting a spacer between the bag and the locking mechanism where the Duze fastener goes through the bag.But I ain't gonna do it or recommend it,with all the bags falling off lately.
Changed my factory cheap azz d'zus clips with Bagger Bolts!
Cheap insurance to not worry about a bag falling off!
http://www.baggerbolts.com/
My wife and I both have 2015 RK's. Her's is rubbing in that location on the right side, mine has not made any contact but there is not much clearance.
I did as a previous poster mentioned, loosened up all the rear bracket bolts and pushed the outer part of the bracket up as much as possible. It is away from the rub spot, but it is still very close.
