Anyone change the front pulley to get lower cruise rpm?.
Yes, because the early FI bikes were geared lower, 3.37 vs 3.15 for carbed bikes. The best mod for the 3.37 bikes is to find a take off 07 66 tooth rear pulley & 1" belt from the 07, then add a 33 tooth front pulley & you have a final drive ratio of 3.08. That would drop the RPMs by 250-300 at cruise, the 1" belt also allows you to run a larger rear tire. I had that set-up on my 2000 & really liked it. You could go to a 34 front & go down to 2.99, but I'm not sure about what belt you'd have to run.
I was thinking about doing this, trying to get a slight drop in RPM at cruise. Just wondering if there are any negative aspects. I have to change out my belt soon anyways, and my primary gasket leaks a little; also replace the rear tire. So, I figure I could do it all at once.
I presume, starting out from a light I could go just a little bit further before shifting up.
Funny, all this talk of raising gearing - I installed a 21T comp to my Dyna TC88 to wake the darned thing up! My ole Evo is fine running at around 90mph on the autobahns. Of course you chaps are all wearing ear plugs, aren't you, to protect your hearing? Best tuning aid known to mankind - for bikers at least! Turns a long cruise into a stroll in the park.
18deluxerider (05-08-2020)
My 88 FXR has a 61T rear pulley ( requiring a softail belt swap)= 15% overdrive.
this is a built motor.
My 1995 FLHTC had the 70T and I would swap to a 65T when touring ( same belt) for a slight overdrive.
the 65T made sense when you consider I am covering 500 miles a day...490 of them in 5th gear
mike
mike
33 Tooth pulley on 99 RKC EFI
Hi all,
I had a 33 steel pulley installed when I had a 07 Swingarm installed on my 99 EFI RKC. My bike had the 3.37 gearing and living in Montana I wanted to drop a couple hundred RPM on the hwy. Bike was a 88" at the time now 95. By BigBoyz calculations it dropped my gearing to 3.23. My speedo now read ever so slightly slow and odometer is 4 miles short per 100 miles. Great mod for me, especially the swing arm with spherical bearings . I have about 60k on this mod..........goldie
Agree entirely. My TC88 was happy at 90+, running at 20mph/1,000rpm. I blame it all on the introduction of 6-speed trans, to reduce emissions, then owners want even less rpm FFS!
