2015 ultra and ultra ltd differences
I'll try the quick rendition.
Twin cooled with higher compression
ABS and linked brakes
Security
6.5 radio
Heated grips
Tour pack luggage rack
Wheels
CB
Color schemes
Badges and fender trim
Not sure if these are exclusive to the Limited
Mid frame heat deflectors
12 volt accessory outlet in tourpack
Daymaker headlight
Fairing air deflectors
Edit to remove mid frame deflectors, daymaker and fairing deflectors and add vivid black inner fairing
Security
6.5 radio
Heated grips
Wheels
CB
Color schemes
Daymaker headlight
My Ultra Classic has the 6.5 radio, mid frame heat deflectors, haymaker headlight, and fairing air deflectors so those items aren't exclusive to the Limited. In my best judgment what I see is the difference is the Limited has the liquid cooled motor with a bump in compression. It has a painted inner fairing vs standard black. Comes standard with a luggage rack and CB. It has a couple different 2 tone paint schemes. Limited weighs more.
Security is a $395 option on the Classic (Std. on the Limited)
As mentioned, the Limited has the "twin cooled" engine with a little higher compression.
The ABS linked brakes are standard on both the Ultra Classic and Ultra Limited.
Originally Posted by Dsm Limited
Radio and security are options. Did yours come with heated grips, accessory plug, the different wheels, headsets, luggage for tour pack and saddlebags and ABS/ linked brakes? Or were those options as well?
Originally Posted by Red
The main difference to me is being able to remove the lowers on the Ultra.
