CCE triple tree and Traxxion Cartridges
I'm not too far.. I went the Traxxion route because they are Made in the USA. If I was to do it again I would go with the CCE tree and tubes and probably the Race Tech emulators and heavy duty springs to start. You're welcome to try it out.
Why the Race Techs? I'm asking because I don't have any experience with front end suspension options. Thanks for the offer!
I didn't see where you modified the upper tube did you grind off or use a lathe, I sent my forks to them for the install for that reason
I also went from race tech gold with stock tree, then added the cce top trees, then to the AK-20 and there is a big difference with each piece installed
Do you remember what spring rates they installed in your forks? mine are 1.15 and 1.20
Thanks for the write up.... !
This is looking like a good combo....
I'd really like to get Howard's 49mm front end trees, but every time I get close to having the $$ saved, life gets in the way and part of the fund gets robbed. I could have afforded this combo a couple times, along the way...
Thanks again...
Thanks again...
Skypilot I do not know the spring rate, I gave dan all my info for weight I will call him and ask what he did, we ended up doing a little shorter length on the build but still have the full travel which is a little longer than stock to compensate for their top nut with the damper screw to clear my 1.5" bars so I would be around .5" lower stance through the cce top tree
I have a couple hundred miles on the new suspension. The handling is great, tight and connected, tracks perfectly. Much more relaxing ride. The compression seems a little stiff, however I haven't contacted Traxxion yet, they may have an answer.
Thanks again...
Thanks again...
As far as last reported, Howard's trees are not available. Not sure how you use an older fender with the new sliders. I would have gone that route if available as it would seem to be the best. However, if it doesn't exist....
it would appear the front fender is the easy part of the swap;
Thanks again for your efforts. Someone always has to go first. I think CCE/Traxxion is going to be a good choice as well..
