Fork stem bearings
08-22-2015, 05:09 PM
Fork stem bearings
I have a 2004 roadglide. Just tore the whole thing down so I can get the frame powdercoated.
Im trying to remove the bearings on the bottom half of the tree.
What have you guys used? certain tools, homemade tools, HD tools?
I have no prob buying the right tool. Im sure I will most likely use it only once but that's ok. I don't mind having tools.
I found a few sites that sell tools to remove and install the races in the neck. Any certain ones work better than others?
08-22-2015, 05:26 PM
I think you invert the tree, heat the race and it'll fall off. After you pack and replace them it'll take a half tube (or about 90 strokes) of high temp tacky grease to get lube to the upper bearing. I didn't have to replace my bearings when I changed my upper triple tree.
08-22-2015, 06:51 PM
Clam shell type puller or you may have some joy driving a chisel around it a few times.
08-26-2015, 10:49 AM
Cant get that style puller in there. You have to heat it up, it's in the manual.
04glideTC
General Topics/Tech Tips
08-19-2015 07:28 PM
Bo_Jangles
12-03-2012 06:59 PM
fiveola
Shovelhead
09-22-2008 07:35 PM
free_rider66
03-15-2008 08:50 PM
HDF Tech
10-14-2005 12:46 AM
