Oil pan removal
Oil pan removal
Is there a trick to lift the oil baffle to be able to get pan out with motor in bike. I loosened up the front mount goes up 1\2 inch but does very little for the back. My brave that goes across the frame might be bent up some which isn't helping, hard to straighten with rear tire of & on jack. Thinking of stealing bike to rafters if have to.
Hope this helps. I've never removed one from this model year.
1. Remove both the engine oil and trans-mission lubricant drain plugs from the oil pan. Drain the fluids into suitable containers.
2. Install lifting strap around frame backbone, and using overhead jack, support vehicle from the top.
3. Remove rear wheel. See Section 2.4 REAR WHEEL, REMOVAL.
4. With a long 3/16 inch ball hex socket driver (Snap-On stock number FABL6 or equal), remove the twelve socket head bolts from the bottom of the oil pan.
NOTE Holes in the frame crossmember allow access to bolts which would not otherwise be accessible.
CAUTION
Remove the engine oil dipstick before attempting to slide the oil pan rearward. Contact with the oil pan will result in damage to the dipstick.
5. Slide oil pan rearward and remove from underside of transmission.
CAUTION
