Some Observations/Concerns
So Friday night i bought a 08 FLHX with 36,000+ miles. I have put about 300 or so miles on it since. I know its not a lot of miles but i have some questions.
1) When starting the bike i have noticed if the throttle is not rolled off there is a clicking/grinding noise and once started it idles at about 3000 RPM's. any fixes for this.
2) Sitting at idle there is some serious vibration in the bike i know this normal for the big twin engines but it seems a little excessive to me. I read on here to help with don't apply front brake which i rarely do unless on a slope when stopped. Also once above about 35-40 mph bike vibrates a lot to where i get that tickling sensation in my hands. Fixes.
3) The shift linkage seem to be vibrating a lot as well. And seems a little loose. I can move it back and forth about half an inch or so and it rolls over about the same. If that makes sense.
I plan to bring it into the dealership and address these concerns with them but everyone knows how that goes. "everything thing seems fine to me". But i just want to get everyones advice on this. Any advice will help guys thanks.
1. Search on this issue, there were some problems just like this on the 08 models. I don't remember the fix. There are some old threads discussing this issue.
2. 07 and 08s vibrate a lot at idle. You can swap motor mounts on the front or do what I did turn the idle up 50 RPM. They tried changing the motor mount position on the 08s but it didn't really help.
3. Normal. I know I don't like it either but it is normal.
1. Bike off, run/stop set to run, ignition off. cycle the ignition 4 times by
Turn ignition to on, count 1-2-3-4
Turn ignition to off, count 1-2-3-4
Repeat 3 more times
Don't hit the start button while doing this.
This will reset the idle
No need to twist the throttle on start up of a fuel injection bike.
When turning bike off, make sure it has settled to idle before doing so ( some suggest removing right hand from grip before turning off)
Repeat 3 more times
There is a reset for the high idle. Turn the switch on for 10 sec. And off for ten secco cons 4 times, that should bring your idle back to normal.
There is also a download available to the ECM that is supposed to help. - one of my friends had an 08 and he said it helped some, but didn't fix the problem. He was always resetting so it wouldn't idle high.
Repeat 3 more times
Repeat 3 more times
The fix for the high idle is is correct. Typically the cause is from rolling the throttle forward slightly at shutdown. Many hold the front brake as they shut down and this can cause a slight forward roll on the twist grip without even realizing it. There is an increase in engine vibration when the front mount fails. Check for obvious cracking and deterioration. The factory mount is sensitive to oil and changing the oil filter without getting at least some oil on the mount is rare. If the mount is then not carefully and thoroughly cleaned it will deteriorate at an accelerated rate. You may need a replacement.
The factory shift linkage ball joints are prone to failure starting at around 30,000 miles. The heim joints installed BEFORE the failure will save trouble on the road. The forward shift shaft on which the toe and heel shifters are mounted can be removed and greased. Check the rear shift arm (the one attached to the transmission) for looseness. It must be tight on its shaft or the splines will eventually strip and it is not an easy replacement.
My new engine mount did not respond to this technique. I had to push the center bolt up far enough to see the shaft of the bolt and look closely to see on what side of the hole it appeared to rub. Then I tapped the engine mount (with the mount to frame bolts loosened) in the direction needed to center the bole in the hole. It doesn't need a hard hit, a piece of pipe, a cold chisel or a long punch will do the job.
The back end of the transmission casting has a tunnel cast into it and the swing arm pivot shaft goes through that tunnel. The pivot shaft is mounted in rubber bushings allowing the shaft, along with the swing arm, transmission and engine to be moved as a unit to set chassis alignment. IN all, the upper and lower links at the front of the engine, the engine mount and the swing arm bushings allow the "power package" to be properly located in the frame.
