Low voltage then not
Old 09-01-2015, 05:24 PM
wrenchman9's Avatar
wrenchman9
wrenchman9 is offline
Default Low voltage then not
Took my new (to me) 07 FLHTCU out for a spin today. About 3 miles down the road the check engine light came on and the battery light came on. Volt meter read 10 volts. I turned around and headed back home and about a mile down the road the lights went off and 14 volts was indicated on the meter. I rode another 20 miles without an issue. Any ideas? Voltage regulator maybe, stator was supposedly replaced by the dealer I bought it from 3 weeks ago.
Old 09-01-2015, 05:55 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
check for loose connections first.
then (as we type almost every day) the charging system diagnostics are in a sticky in teh electrical section of the HD forums tech board.
you can test the entire charging system in minutes
https://www.hdforums.com/forum/elect...sting-1-a.html
mike
Old 09-01-2015, 05:59 PM
69cj's Avatar
69cj
69cj is offline
Go through the test procedure in the manual BUT, my money is on the voltage reg. Bad stators stay bad. By the way, when I replaced mine the chrome one was 40 bucks cheaper than the black one. Go figure?
Old 09-01-2015, 06:04 PM
Duracell's Avatar
Duracell
Duracell is offline
Received 1,654 Likes on 580 Posts
Another vote for the voltage regulator. When they fail its more often than not an intermittent problem at first.
Old 09-01-2015, 06:10 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,541 Likes on 3,793 Posts
That is not the way voltage regulators fail unless battery is already bad or low charged. The connection may be loose on the battery or starter. (hopefully)
Old 09-01-2015, 06:15 PM
69cj's Avatar
69cj
69cj is offline
Originally Posted by RIPSAW
That is not the way voltage regulators fail unless battery is already bad. The connection is loose on the battery or starter.
Your opinion, stick with it if you want. Your theory is a possibility but not gospel. That's why there's a test procedure.
Old 09-01-2015, 06:18 PM
jrpetrie's Avatar
jrpetrie
jrpetrie is offline
mine did the same thing, was riding to Sturgis ,stopped and got gas about 10 miles later the battery and check engine light came on. about another 30 miles down the road they both went off and back up to 14 volts. Then we were headed back and I noticed 12 volts, luckily we made it to Casper WY to a Harley dealer . Bad Stator 5 hours later back on the road
Old 09-01-2015, 07:34 PM
Jackie Paper
Of course it's just my opinion and where I would start. No gospel here. Never meant to be a thumper... However, you start at the basics. If you have a loose connection, testing sucks.
If it's the stator or regulator, sure, it could drop to 12 or so but probably not 10 and then back to 14.
But like you say, say my opinion and where I would start.
my two cents on voltage.
Rev. 081815
Remember, the best made brand new battery that has been on a maintenance charger for 3 days that has a loose or bad connection is no better then a boat anchor with a loose rope. The connection can get loose after one ride if the battery is not anchored and the wires are short and get tugged in a direction that can unscrew the bolts.
After a good 24+ hour maintenance low amperage charge, with the charge light in the solid green and the battery has set about 24 hours off charge, voltage should be about 12.8 volts.
12.8 = full charged
12.6 = 75% charged
12.3 = 50% charged (Lot of new modern cars with system protection will not even click at this point but will have good headlight beams showing)
12.0 =25% charged
Always check both the terminals at the battery lead and also at the terminal on the wire. That helps to verify connection. With a DC volt meter (one that has a feature to lock high and low reading is best) hooked across the battery terminals and reading 12.8 or so, crank motor and while its cranking it should not drop below about 9.6 volts and as soon as it starts and throttled up to 2000 rpm, voltage should read around 14.8 volts. The 2000 rpm is the bench mark standard. Ignore idle output. Ignore output above 2000rpm unless it exceeds 14.9 volts. That is a sure indication that regulator is bad.
The crank check shows a rough check of the reserve amperage capacity of the battery while cranking with a 150-200 amp load on it. The 14.8 shows a good alternator and if you leave it on a while as the regulatory will drop the voltage a little showing itself working. However, with the lights and stuff always on, it will never drop back much. If you have a lot of options, most modern bikes will not show 14.8 charging volts at idle but stock newer bikes will be close. Older bikes with lower amperage output not so much. However, 2000 rpm is the bench mark for the standard 14.8 volts.
If you think battery is good and something is draining it sitting, now would be a good time to check for drain problems. Go to Harbor Freight and get you a AC/DC meter for under $25 or so. http://www.harborfreight.com/ac-dc-d...ter-37772.html Make sure it has DC amps draw, DC voltage, resistance and AC voltage. Key off. Remove the negative cable off the battery. Set meter on DC amps. Hook the meter lead to cable and the other to battery. How many milliamps (mA) is it drawing? It should be no more then 6 mA which is the ECM (1), speedometer (1), tac,TSSM (1),HFSM (1) and voltage regulator (1)
When a battery wears out, a good charge will show fairly good voltage, but the battery can still have very low amperage capacity which will show in the crude crank test above, but it really should be checked after a good charge by removing it from bike and getting a free check at a place like AutoZone that has a fancy load meter check that gives you a print out of the battery health. Battery MUST BE CHARGED to check it. Be sure they set their meter to correct cold cranking amperage stated on the battery. Never charge the AGM absorbed glass mat battery with a regular car battery charger unless it is a newer one that says safe with this type of battery. Also, by taking battery out you now know you have good connections. Vibration tends to loosen the connections or a little corrosion will prevent charging or cause starting problems.
Using the maintenance charger can get more years from a battery but be careful here. You do not want the last start 5 miles from home. If it still grunts when you first hit starter or kicks back with a bang, replace it. After a few years, charge and pull battery and have it checked for cold cranking amperage ever spring. Even then, if it grunts most ever start, I would replace it. If they have one that fits your bike, Wal-Mart's AGM absorbed glass mat battery is just as good as any for one third to half the money of a Harley Battery. Do not jump, push start or run bike with a half dead battery except in an emergency. If a bike battery is down and you jump it, throwing all that amps to it from a big car battery especially one that is running can wreck a bike regulator or charging system. Charging a worn out battery can kill alternator stator or the voltage regulator or both. Probably ending in a big dollar repair.
It is also a good idea to always check your battery at 2000 RPM with your meter set to AC. If by chance, the regulator goes bad, sometimes it will let AC come thru. That is a sure sign of a bad regulator. The older stators with two wires are a two phase AC system. Lot of people call it a single phase but it is two phase. The AC voltage you see appears single since you check it AC across the two wires since there is no earth ground. If you were to check one wire to an earth ground, it would show one half the voltage that you would see when you check the two wires together on the bike. Same with the other. Together they double and are two phase. The newer three-wire system is a 3-phase AC system for the higher amperage output.
Also remember, when starting a Harley, hit the starter and hold it in till it is firing on both cylinders and running before letting up. If you let up before it’s running, quiet often, it actually take an FI motor longer to start. There is a fraction of a second more for a long stroke Harley then a multi-cylinder car for it to get going. If you do not do this, it will kick back with a bang, sneeze thru the intake or crank a lot longer the second time or shame on you the third time. Also, if you have a habit of doing this, the starter solenoid switch contact will only have half the life it could. You cannot hurt the starter. The starter gear has a sprag clutch. There are drive pins in it that as the gas motor catches and run, it outruns the starter motor drive and disengages it from the electric motor. If you hold it in a little too long and listen carefully, you will hear the sprag clutch run up the ramps and slip. Makes a sizzle hum. This will show you your starter sprag clutch is OK.
Old 09-01-2015, 07:54 PM
Duracell's Avatar
Duracell
Duracell is offline
That is almost always the way they fail. The diodes begin to degrade within the regulator, when they are hot they stop conducting. If the bike runs long enough without the regulator putting out the battery voltage will drop as low as 10v or so. Much lower and it will shut off. If the regulator begins to conduct again it will show 14 or so volts on the gauge as it begins to recharge the low battery.
Many dealers will even hit a suspected voltage regulator with a blow dryer or heat gun if it fails to pass voltage after its hot it'll be replaced under warranty.
Old 09-01-2015, 11:18 PM
wscott's Avatar
wscott
wscott is offline
Rev. 081815
12.8 = full charged
12.6 = 75% charged
12.0 =25% charged
RIPSAW,THANKS A LOT FOR THE INFORMATIVE CHARGING SYSTEM DIAGNOSTIC CHECK INFO!
Opps,sorry about caps.
Scott
Quick Reply: Low voltage then not
