What is it called?
What is it called?
All - I've an '07 EG and I recently had a "no brake light" problem. The headlight relay was clicking and I had already tried a new tail light and that did not fix it. While the left cover was off, I was fiddling with the wiring harnesses just to make sure nothing looked bad.
I was able to wiggle the harness that leads up to some kind of relay that is right behind the battery, slightly left and in a square rubber grommet looking thing. Wiggling that harness close to the relay made the back light work. So, I took it apart and cleaned all of the connections and all has been good.
Well, I got to thinking that I should probably replace that thing. What is that relay called? I can't find reference to it anywhere. It seems that brake light power goes through it after the brake relay - that makes no sense to me to have another relay in the same route to the back light.
What the heck is it called? I want the peace of mind of a new one.
Thanks.
Thanks.
I don't think it's the brake relay. That's smaller and fits into the fuse panel. This is larger and has more wires. It fits into the rubber grommet that actually has two square holes in it. Only one of my squares is occupied - and it's by this larger relay looking thing. You can hear the brake relay in the fuse panel clicking when the bike is off and you squeeze the lever. That part works OK even though I'll replace it once I figure out what this other thing is.
I believe that number to be correct for the brake. The microfische (Ronnies,) calls for that number for both the brake and starter. The other relay, that my '00 runs is 31504-91B, is for my ignition and brake both and that may be what you're running. (That one fits under the seat.)
Hope that helps.
Hope that helps.
Hope that helps.
Hope that helps.
