Rotella T ????
ROTELLA T COMES IN MULT GRADES INC 15W-40 ROTELLA T IN STD DINO & SYN , 5W-40 SYN ALSO CALLED ROTELLA T ,ETC.
So which grade & type oil are you reffering to?
Bottom line is will the primary self destruct using improper oil thats not properly designed and or formulated to be used in an HD primary,no it wont,well not anytime soon.
But would using an oil specifically mfg'd and formulated for use in HD primary be a much better choice that could extend the srv'c life of everything in the primary thats lubed by prim oil,YES!.
See below for a hi quality oil specifically mfg'd & formulated for an HD primary case.
Scott
http://performanceoilstore.com/products.asp?cat=65&pg=4
Spectro Heavy Duty Primary Chaincase Oil 1-qt
Spectro Heavy Duty Primary Chaincase Oil 1-qt. This sheer stable petroleum is designed to withstand the punishment of high loads, and contains special polymers to provide exceptional clutch engagement and temperature stability. Meets full OEM requirements, and should be used according to manufacturers’ instructions. Formulated specifically for Harley® Sportster and Big Twin applications. Low drag, low friction loss SAE 85w viscosity helps eliminate clutch “drag” and slipping.
List Price: $12.04
Price: $7.95
When i questioned shell oils engineering staff with respect to rotella t 15w-40 in std dino and syn along with the 5-40 syn rotella t on another oil related topic i was researching at the time the shell oil engineer told me those oils had a small amount of friction modifiers in their additive pkg's.
So with that said i'd not rec them for use in a HD prim case especially with a wet clutch because over time in some cases/not all it could lead to clutch slippage.
If your a conservative rider that always ride 1 up with no bag loaded in flat areas not loadeing the clutch as much your likely ok.
But if the bike is modded for a little/or a lot more power ,gets ridden 2up often more aggressively too in mountains loading the clutch a lot more thats where you could over time/miles eventually run into a clutch slip issue especially if your still running stock clutch spring.
Scott
Scott
Scott
matter what anyone else said................
The Shell Rotella T6 not T5 or just Rotella is a syn oil spec'd for wet clutches. When you talk about Rotella you must identify the specific version. All squares are rectangles not all rectangles are squares.
I use it in all my bikes now from a Street 750 to a 120R. Walmart has it in 4 qt. containers for under $20. If it did not work with a HD wet clutch it would show up in a clutch being challenged with a 120R. All Shell employees that have HD's use T6. I have talked to many at various semi truck shows over the years where Shell brings in a display and reps. Of course they get it cheap.
Good enough for 600HP diesel engines good enough for a Briggs and Stratton Harley Davidson.
the shell rotella t6 not t5 or just rotella is a syn oil spec'd for wet clutches. When you talk about rotella you must identify the specific version. All squares are rectangles not all rectangles are squares.
I use it in all my bikes now from a street 750 to a 120r. Walmart has it in 4 qt. Containers for under $20. If it did not work with a hd wet clutch it would show up in a clutch being challenged with a 120r. All shell employees that have hd's use t6. I have talked to many at various semi truck shows over the years where shell brings in a display and reps. Of course they get it cheap.
Good enough for 600hp diesel engines good enough for a briggs and stratton harley davidson.
jj
