1999 ultra classic
1999 ultra classic
I have a 1999 ultra that sat for
1 1/2 years, now no fuel to injectors.
Drained old fuel and replaced. When the ignition is activated the fuel pump does Not make noise , but when ignition is switched off is powers down
( audible sound).
Any guidance would be appreciated,as well as recommendation for parts purchase.
I'm not impressed with eastern Harley in riverhead.
Thanks Montaukharley
( audible sound).
sounds like you'll have to open the tank and check for gunk in the tank from the old gas- also inspect and possibly replace the fuel pump and fuel lines.
no big deal, just messy
your Magnetti-Marrelli EFI system was used 1995~2001 and can be converted to carb for $600~$1000 depending on the DIY. ( some riders like this system- many of us think it is crap)
Most dealers are hesitant to work on older bikes- they hire kids who don;t have a knowledge base or experience with anything built before they were 15 years old....and good techs don;t stick around for 9.53 an hour at a dealer.
I'm sure there are independent shops in your area
welcome to the forums
Mike
Mike
I have a 2000 Ultra that has the MM efi and put a Dobeck TFI on it to trim it similar to a carb. When dialed in, it runs great. I gave a call to them and told them my setup including exhaust and they gave the setting and she pulls nice. Of course this will be after you get her to fire up, but a way to give the MM setup a way to dial in.
I have a fuel pump I bought on ebay. It fit with no modifications, works fine. You can get a lot of the in tank parts from Drag Specialties.
dabrogger
01-14-2010 08:42 AM
Tanker2
02-12-2009 02:29 PM
