Base gasket leak it not covered under warrantee? WTF!!
Most manufacturer's have guidelines for leaks and usually a seep is not a leak. I work for a German car dealership and the manufacturer has 3 stages of leaks and stage 1 is just clean it off and test drive it. if nothing returns after drive you are done, no repair. So they may have rules for this but some dealers may not follow it and take the work anyway. Mike
2014 limited, had same thing happen to my bike less than 500 miles. took it in and they looked at bike told me it was assembley lubrication. At first I didn't believe them, so I went out on the showroom floor and looked at every new 2014 limited. They all had a the same film in the area you showed. when the bike is new and it gets up to operating temp you will see moisture in that area. I now have 6000 miles on the bike and its no longer showing moisture in that area. it is definitely assembley lubrication.
Received 47,779 Likes
Originally Posted by bagman1
I think what you need to do is clean it off and ride it about 5k miles and report back if its still leaking or not, otherwise this post will grow to 25 pages of opinions and speculation. If it is leaking in 5k miles go to another dealer!
