U-haul trailer?
U-haul trailer?
Hello all -
Has anyone ever used the U-Haul 5x9 trailer (with ramp and built-in motorcycle chock) to haul a touring-sized Harley?
How well does the built-in chock up front work?
Will it keep the bike upright while you tie it down?
Here's the trailer I'm referring to:
http://www.uhaul.com/Trailers/5x9-Ut...amp-Rental/RT/
Only need it for a trip of about 350 miles (one day).
Thanks....
Thanks....
I used one without a chock and it worked fine, only went 8 miles though. I used a 6x12 one and hauled 2 road kings about 80 miles and was ok. Just check your tie downs, ball for tightness, if the hitch is sloppy it makes everything move.
Just check everything periodically and youlll be fine. Triple check the rails or tie down loops in the trailer, remember these are abused by dumb people that rented before you.
I found the ribbed floor held the tire in the groove very well.
Do you know they have a motorcycle specific trailer you can rent? Its low to the ground and has a nose shield to protects it from rocks. Thats what I was going to rent that time but the welded rails had cracked welds so I took the 5x9 one.
I've used the Motorcycle Trailer to take my Chopper, I'm building, to the welder. It pulled nice behind my Suburban but it was a lighter bike.
If you have an option, get the newer trailer with the LED tail lights. I've used an older and a newer Motorcycle Trailer and the newer was much better than the older.
The Motorcycle Trailer is only about $15.00 per day. I would think the 5x9 Utility Trailer with Ramp would be more.
From their website: Our motorcycle trailers for rent have a maximum towing capacity of 950 lbs.
5x9 Utility Trailer with Ramp had a loading capacity of 1,600 lbs.
I used one to bring a bike from Virginia to San Antonio.
Works great.
It will not hold the bike upright without a strap on it, however.
Ride it into the chock, put the kickstand down, strap the front left, but don't pull into the suspension at all, strap will feel loose. Strap the front right, as you tighten the front right, stand the bike up, this will pull the front left tight, tighten the front right until the bike is level. Add a few more straps to stop lateral movement of the rear, and for safety.
Easy peasy.
Works great.
Easy peasy.
mine is a little different twist I own a flat bed 10' with a ranp and bought a chock. as long as I get the my 85 Electra glide in straight it will stand while I tie it down. When it is a little off, it still easy to get one tie down on, on the away side to hold it upright. I haul my my bike a lot, mainly to get my trailer where I need it, it doubles as my boat trailer for a 12 ft port-a-boat (with wheels) I have a v mounted on the top rail that the front of my boat sits in and both work great for me.
I used the same U-Haul trailer a couple of weeks ago to pick up my bike from the dealer in Albuquerque where I bought it. Didn't have anyone to drive me up, so I had to trailer my bike home. Strap it down as SafetyMan indicated above and you will be fine. I stopped after about 5 miles to re-check the straps since the road was bumpy and if anything came loose it would have. After that, I checked them when I stopped for gas/food/restroom (yeah, I took my time, enjoyed the scenic desert view and rain coming down).
crabio
10-18-2020 07:40 PM
