Coming home of work my Right turn signals quit working , the red key light came on, and after I got home I shut the bike off, and back on, and the Right turn signal came on without touching the switch, and when I try to cancel that signal, it does not stop the light, but if I hit the left it stops, and the left one works as normal, and if I hit both the hazards work. Where to start?
Have you changed anything in the last few months? Some people have had switch stick in a bit, a bulb that is starting to go and causing in correct resistance at tsm (turn signal module) or a bad TSM.
