I'm all out of clutch adjustment
Old 09-23-2015, 04:13 PM
Mertoid's Avatar
Mertoid
Mertoid is offline
Default I'm all out of clutch adjustment
My 2011 Street Glide has run out of clutch adjustment. I've got the cable adjuster maxed out and even had to adjust the setscrew on the clutch to a quarter turn just to not have so much freeplay at the lever.
What has worn out? Maybe cable stretch along with clutch plate wear? Throwout bearing going? Very recently changed the primary lube and saw nothing unusual come out. Clutch never slips while riding and still feels normal. Any ideas on what to look for before I tear into it?
Old 09-23-2015, 04:19 PM
05UltraBob's Avatar
05UltraBob
05UltraBob is offline
My first guess would be cable has stretched.
DanHappy (05-10-2022)
Old 09-23-2015, 04:41 PM
twistr's Avatar
twistr
twistr is offline
Did you perform a proper clutch adjustment procedure?
Follow service manual procedure to adjust clutch. I doubt the cable stretched...JMO
Old 09-23-2015, 04:42 PM
bmaier's Avatar
bmaier
bmaier is offline
Go 1/2 to 3/4 turns out on your clutch rod adjustment
Old 09-23-2015, 05:04 PM
Mertoid's Avatar
Mertoid
Mertoid is offline
I normally set it to 1/2 to 3/4 turn out, then adjust the cable for proper lever freeplay. Now I get too get too much freeplay at the lever when I set it to 1/2 to 3/4. The only way to lessen the freeplay now is to have less clearance on the pusher rod.
Old 09-23-2015, 06:31 PM
uscanuck's Avatar
uscanuck
uscanuck is offline
I don't think your cable is stretched. Try this:
Loosen cable adjuster til the lever is about half way to the grip. Turn the adjuster screw in til it makes contact, keep turning while working the lever, the lever will move out away from the grip. If it moves all the way, loosen the cable adjuster some more, repeat the process. When the lever doesn't move away from the grip anymore while tightening the adjuster screw, the ***** are bottomed out in their ramps. Now you can make sure that the adjuster screw is barely touching the rod, and make sure you have some free play in the lever. Now, back out 1/2 to 1 turn, and adjust the cable.
Harder to write than actually do it.
The following 5 users liked this post by uscanuck:
Geoff (05-04-2023), hbsoldier3 (05-24-2019), motorbtr (05-10-2022), Ragtop (05-16-2019), rubberguy (08-26-2019)
Old 09-23-2015, 06:33 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
adjust the clutch.
misadjusting the clutch to correct for a cable problem will just burn up the clutch.
as above, ensure that your ball and ramp are set correctly
take the time to inspect your clutch cable- maybe it is getting ready to break.
mike
Lowcountry Joe (05-25-2019)
Old 09-23-2015, 06:42 PM
bad tappets's Avatar
bad tappets
bad tappets is offline
Are you loosening the cable adjuster all the way before adjusting the clutch; then adjusting the cable?
Old 09-23-2015, 07:23 PM
Vernal's Avatar
Vernal
Vernal is offline
Received 7,284 Likes on 1,903 Posts
A common mistake is doing it when the bike is warmed up.
This is another reason I love my Rushmore
Old 09-23-2015, 07:57 PM
MNPGRider's Avatar
MNPGRider
MNPGRider is offline
Replacing my clutch cable solved all my clutch problems that I had since new. I should have done it years ago. My stock cable seemed to have too long of a cable for the sheath, so the adjustment was always way out to the end (the adjuster on the front down tube.)
The new cable's adjustment is now only about half way up the threaded adjuster, and I now have my clutch lever set so that the friction zone engages with the lever, under my index finger, about 3/4" from the grip.
Quick Reply: I'm all out of clutch adjustment
