A word about installing ROCKOUT rocker shaft inserts...
#121
Received 1,934 Likes
#122
__________________
NO, they DON'T all do that!
Also on amazon.com...
#123
I just did my second install. Took all of 1 hr 15 min. ( that's with waxing rocker boxes) If your handy it can be done with 2 simple wrenches. The short ones here in the picture No chance of over torque with them. When both rockers are down I lined up the rocker shafts with a simple Allen wrench that is very close to the same size as the bolt . One bolt at a time. The incerts about fall in place. If they don't it's not lined up. Have to say it made a big difference on the older TC I did today
I'm thinking at this point I might try your 1 bolt at a time method using a dental mirror/pick, 5/16 drill bit shaft, keyboard air & Q-tips w acetone, whatever,, to clean the holes & line up the shaft. If the inserts then press into place "easily", I'm GTG, if not I can continue with the prescribed method. "Hmm, maybe I've just answered my own question" .
I'm no engine mechanic but have worked for decades offshore with HP brass fittings as well as reloading brass for firearms and have a pretty good sense of how things feel when going right vs when not,, plus,, there's a spare .
#124
For guys that are considering installing the Rockouts one at at time.... I strongly suggest you loosen all the bolts just enough to let the support plate move, but not lift up. The insert is a very close fit to the bolt when installed, if the support plate was installed too close to the bolts & tightened down the insert will have nowhere to go when drawing in. There is a "parting line"... a ring of aluminum the insert needs to get past that is right about where the shaft is. If the insert hits this rather than moving past it it likely will not go in.
And at that point it's not much more to take the assemblies out & do it on the bench
John @ Rockout
John @ Rockout
#125
I did my installation on Friday, on the bench with all new bolts and breather kits. I thought my Ultra was pretty quiet to begin with, but the difference in the sound of the engine now is nothing short of amazing. I even thought that there was a bit of a placebo effect going on in most of the posts regarding the Rockouts, as I was quite skeptical that it could make that big of a change. I took the bike for a 3 hour ride today without earplugs. I have never done that with any Harley I have owned. That small but nasty little ticking took away the pleasure of riding. Not anymore! It's hard to believe that something this simple could make such an extraordinary change in the tone of the engine. I'm guessing that these posts have already made it to the desk of the engineers at Harley, and it wouldn't surprise me if the 2017's include this fix. Um, maybe not. Thanks!
DJK
DJK
#126
DJK
DJK
#127
DJK
DJK
I always like to let my product/users speak for themselves.... I couldn't have said it any better than that
Thanks for your support, and have a great weekend.
John @ Rockout
#128
#130
Thanks man, welcome to the tap free brotherhood
Thanks again to everyone for your continued awesome support
John @ Rockout
For ROCKOUT information & purchasing please click the LINKS below...
John @ Rockout
